Re: super A block swap
Posted by Janicholson on May 20, 2012 at 19:51:16 from (96.24.99.126):
In Reply to: super A block swap posted by Pakratt on May 20, 2012 at 18:41:46:
Do it. RIdge ream the sleeves, Hone them at 45degree crosshatch angle with 400 grit hone, put new rings in it and go to work. Jim
