Re: Farmall 806 diesel quit running
Posted by Dieseltech on May 21, 2012 at 04:10:26 from (199.16.223.2):
In Reply to: Farmall 806 diesel quit running posted by Super c guy on May 20, 2012 at 17:39:26:
Sounds like weight retainer ring in pump is breaking up as usual. Can comfirm by loostening 2 timing cover screws with a catch can under pump to collect fuel as it leaks out. If tractor runs OK flex ring is broken and plugging return in top cover. Pump will need service or more expensive damage will happen. Top return fitting is used to control housing pressure, can be cleaned if not damaged. Will need replaced if ball is knocked out.
