First of all you will need to park it nose down on a hill or drain out a gallon or so of 90W. Otherwise it will pour out after removing the seal cage. Besides the seals, you really need to replace the gasket on the bottom of the cage. Get one of those before you start. There are just 2 bolts to remove, then work the cage off but HOLD the PTO shaft so it doesn't come out with the cage. That happened to me last time! Simply set the cage upside down on a vice or your workbench and punch out the old seal. If it is original it will be pretty thick. Then install the two new ones and bolt it back up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
