Re: Farmall 806 diesel quit running
Posted by ejr-Ia. on May 21, 2012 at 10:57:17 from (204.11.182.30):
In Reply to: Farmall 806 diesel quit running posted by Super c guy on May 20, 2012 at 17:39:26:
If that check valve is pluged it will not run.I have taken that glass ball out and ran it that way.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
