If it has a Starter/Generator system, it will require the use of a 12v starter/generator. The change to that system is model dependant. A 12v regulator, the new Starter/Gen and light bulbs, a ballast resistor for the coil, and you are done. If separate starter and generator, the diagrams below will work.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
