Re: what are these 4?
Posted by MisterT on May 21, 2012 at 11:06:14 from (67.55.162.174):
In Reply to: what are these 4? posted by stanhoist on May 19, 2012 at 06:21:06:
No, not used in place of the coulters, but used in ADDITION to the rolling coulters. The plow jointer is like a miniature moldboard. It actually will cause that first little bit of earth to roll over and be buried under the earth the main moldboard is turning over, thus creating a much cleaner, neater job of plowing, with virtually NO little bits of grass, cornstalks, etc. left on the surface.
