Re: M idles on main jet
Posted by wayne in mn on May 21, 2012 at 12:14:58 from (64.118.12.213):
In Reply to: M idles on main jet posted by Dalrymple on May 21, 2012 at 09:45:00:
Clean out the idle circuit! Remove the idle air jet and run a fine wire (soft, such as copper from a piece of taillight conductor)through the passage AND jet. Use brake cleaner (evaporates completely) to spray through each passage, blow dry with compressed air, and re-assemble.
Set the idle air adjusting screw at 1 1/2 turns out and main jet screw at 2-2 1/2 turns out for starting point.
