Posted by CNKS on May 21, 2012 at 15:05:03 from (216.144.104.128):
In Reply to: M idles on main jet posted by Dalrymple on May 21, 2012 at 09:45:00:
If the PO modfified it for pulling, hard telling what you have. Take the carb off, disassemble, soak it overnight in real carb cleaner, the type that will peel your skin off, not parts cleaner. Blow it out with compressed air. Every inlet to the air must come out somewhere. You may have to clean the passages with wire as a last resort, I don't like to manually clean jets, etc, but you may have to. If the choke control is on the inside of the carb it is a SM-up carb. If it is on the outside it is an M carb. The SM carb is not adjusted like the M carb (main jet screw in until rough, out until smooth). Instead max power is with the screw 5 turns out, in a turn or so with light loads. I doubt if it will pull anything if 3 turns out. The main jet is supposed to have nothing to do with idle. Your idle system is full of crud. If you cannot get it clean, you need another carb. or at least put the right jets in it, provided you can get the old ones out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
