Re: 450 gas
Posted by Mike1972chev on May 21, 2012 at 16:31:13 from (99.50.230.30):
In Reply to: 450 gas posted by metalmender on May 21, 2012 at 15:21:25:
You broke a crankshaft???? WOW! IDK if I would blame all of the "dieseling" for the broken crank???
I TOTALLY agree with checking the timing. I wouls also look at all of the mechanical advance parts inside the distributor for wear,breakage.
Things to look for in your "teardown".Excessive carbon build up on piston tops and combustion chambers/valve faces.
ALSO,what was LOW idle set at on this engine?????? If it is set TOO high,THAT will cause "run on"".
If you had a REALLY high compression motor on "cheap" fuel,it will "run on" sometimes.
I am betting that Crankshaft was "stress fractured" for a way long ,long time before it broke???
