Posted by gbs on May 21, 2012 at 17:46:23 from (69.59.107.136):
In Reply to: Zenith Carb Problems posted by JRSutton on May 21, 2012 at 15:16:04:
don't know the proper float height right of hand, but as a general rule if you invert the top housing the top of the float should be level with the housing from one end of the float to the other,replace needle and seat yours is probably distorted or bad,one thing i learned the hard way with neoprene needle tips is don't apply any pressure to them when adjusting or checking for sealing not even slight finger pressure as it will distort them causing it to leak until it returns to it normal shape also make sure to install the spring clip from needle to float it helps prevent sticking
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
