Re: super A block swap
Posted by pakratt on May 21, 2012 at 18:13:53 from (96.39.84.115):
In Reply to: Re: super A block swap posted by ShaggyM on May 21, 2012 at 05:24:41:
Jim and ShaggyM thanks for the info.It would be my preference to use all of the Super A internals.I was not aware that I could modify the block.I guess I didn"t put much thought into it.I will go talk to my local machine shop.The guy does good work and he is reasonable.
