Re: Farmall B Generator question
Posted by luv2wrench on May 21, 2012 at 19:37:43 from (72.107.45.241):
In Reply to: Re: Farmall B Generator question posted by gene bender on May 21, 2012 at 19:08:58:
ok. gunna try the orginal switch because a new one is 100.00 from case ih. part number 128967a1.
all the wiring will be new.
Your talking about the armature post marked A rigth? Not the F post.
from what i can tell the F terminal on the cut out relay is a sense wire in the ameter box? its wired to a connection to the ameter housing. Is that how it determines the load on the system and how much to charge?
