Re: Famall B valve clearence
Posted by gene bender on May 21, 2012 at 20:01:46 from (67.55.226.143):
In Reply to: Re: Famall B valve clearence posted by luv2wrench on May 21, 2012 at 19:41:04:
OK i would take out the new plugs and lay them in order so you know which cycl they came from. They should all look the same. I just finished new sleeves ect. Had a miss took all the plugs out in order then compared found one that looked bad and replaced with another new one problem solved. AC 87 Starts on the first fire now and runs just fine like its supposed to.
