Re: What Battery Do I Need For an H
Posted by old on May 21, 2012 at 20:33:03 from (209.86.226.32):
In Reply to: What Battery Do I Need For an H posted by dstates on May 21, 2012 at 20:20:29:
If all your going to do is load it on a trailer to bring it home just go with a 12 volt car or truck battery that you have at the place already. Shoot a good strong lawn mower battery if that tractor is an easy start tractor will do the job just fine. Once you have it home then you can worry about what battery to go with but I will say this. Since he had a 8 volt battery in it then it had some sort of starting problem since a 8 volt battery at best is a band aid fix to other problems. And if your worried about a 12 volt battery hurting any thing NI it will not I use them all the time to load tractor that are 6 volt. Shoot you can if you are careful just use the battery and starter motor to load them done that many times also. Just back up close to the tractor and put it in 1st gear and have help tp block the wheels.
