Re: Idle after 12v conversion
Posted by old on May 21, 2012 at 21:17:05 from (209.86.226.32):
In Reply to: Idle after 12v conversion posted by TylerFarmallH on May 21, 2012 at 20:30:31:
Check and make sure all the plug wires are hooked up as they should be. Or if you installed a ballast resister it could be the wrong size and you now have a weak spark. Check your spark and make sure it is a good blue/white and will jump a 1/4 inch gap
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
