Re: What Battery Do I Need For an H
Posted by mkirsch on May 22, 2012 at 05:29:10 from (64.80.110.74):
In Reply to: What Battery Do I Need For an H posted by dstates on May 21, 2012 at 20:20:29:
I agree with using the 12V battery to start it for loading. You're not going to hurt anything.
Ultimately you'll need to make a decision whether to keep it 6V or make it 12V. The tractor probably needs starter work, generator work, new battery cables, and a new battery. Hopefully you have a good starter shop in the area that you can take both starter and generator to, and have them clean up the commutators and install new brushes. Install a new regulator and you'll be off to the races for the least amount of money.
If you end up having to replace the generator, you should then consider converting to 12V. An alternator is much cheaper and overall more reliable.
