Re: Idle after 12v conversion
Posted by david G on May 22, 2012 at 05:48:02 from (205.215.206.18):
In Reply to: Idle after 12v conversion posted by TylerFarmallH on May 21, 2012 at 20:30:31:
If if is a distributor, the negative (-) terminal on the coil should go
to the points. You will also need a coil with internal resistor or
ballast resistor between the positive (+) terminal and the ignition
switch.
A magneto will not care.
