Sorry to disagree, but I would not connect a 12 volt battery to a 6 volt system on my own tractor or anyone else's. If the tractor is fitted with a voltage regulator, connecting it to 12 Volts will not do the regulator a scrap of good and may in turn cause damage to the generator. I think what is needed is the correct dimensions of a Farmall H battery box. Then the correct size battery can be fitted and the tractor started. The original battery was rated at 88 amps at 20 hour discharge rate. I personally use the largest battery that will fit in the box; makes it easier to start the machine in the cold.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
