Is it easy to crank the motor by hand just after it dies? If not, then you have something seriously awry inside that engine, which will want serious looking into before it destroys something. If yes, then you have other issues. Not sure about the 6 volt system being the problem, because the tractor starts OK after a minute or two. Perhaps check the state of charge in the battery while the engine is running. If there is a charging fault, it may in fact be draining the battery or over charging it, both of which do not help with starting. As to the stopping problem, fuel issues and spark issues are the easiest to sort out and should be checked first if the motor is not tight to turn over by hand. Good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
