If it's not overheating and expanding too much (and you said it's not), then it's something that can't expand as much as it wants to.
As long as you're SURE it's locked up, and sounds like you are. I'd do as sadfarmall suggested and hand crank it next time it stops just to see(if you REALLY want to even try running it again - not sure I would).
In addition to the ring gap - I'd check the piston to cylinder clearance while you're in there. But I'd guess the rings are more likely the problem.
Total PITA, but if you just bite the bullet and do it - not the end of the world.
I'd at least pull the head and check the cylinder walls - assuming they were freshly cross hatched when you assembled, if you see any vertical scoring, it's more incentive to continue to the rings.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
