Posted by John T on May 22, 2012 at 11:33:30 from (216.249.82.117):
In Reply to: SH not sparking. posted by GordoSD on May 22, 2012 at 08:53:40:
I agree with Bob M.....Since the engine dont tend to stop on the TDC of a piston under compression, the points are usually closed, they open at TDC of a piston to fire that pistons plug THEREFORE with the ignition on and her just sittin there Id expect 6 volts on the coils LV primary input BUT ZERO VOLTS (with respect to ground) on the output where the coils LV primary output wires to the distributor.
If not, the points arent closing or arent wired right or the wires bad from coil to distributor or the distributor or points arent getting a good ground. Check the wire inside the distributor from the points terminal to the pass through stud where the coil wires !!!!!!!!!!!!!!
The coil cant ever conduct current until the points are closed and the to ground circuit (via points) is complete,,,,,,,,,,that means a test lamp on the coils LV primary output should go OUT when poinst are closed as that becomes ground
Run my Troubleshooting Procedure for more detail..
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
