Re: h misses a beat
Posted by pete 23 on May 22, 2012 at 17:56:09 from (74.32.231.176):
In Reply to: h misses a beat posted by jhakenwerth on May 22, 2012 at 14:55:49:
I would suspect the weights and springs and shaft in distributor not providing proper advance curve for spark timing. A timing light at low idle should show timing not bouncing back and forth and it should be very near top dead center and fully and gradually advance as you increase engine speed. Total advance will depend on what shaft you have in distributor and what pistons and head you are using. Fire craters with gas head use 22 degree, flat head pistons will have 30 or 40 degree advance. I prefer 30 as 40 was for original bore cast pistons but few ever changed them when putting in aluminum over bore sleeves.
