Re: Now the liftall leaks
Posted by pete 23 on May 22, 2012 at 18:07:09 from (74.32.231.176):
In Reply to: Now the liftall leaks posted by jbp on May 22, 2012 at 08:19:59:
I use a brass drift and hammer and give nut some good wacks counter clockwise. You might feel like it isn't working but you have to stay at it for a while. If that doesn't do the trick you may well have to remove pump from reservoir and then you can put something up in the suction port to lock the gears. When I have to go that far I just take them all apart though.
