Posted by CenTex Farmall on May 22, 2012 at 22:54:24 from (166.183.187.52):
Dad's 560 has a leak down problem in the hydraulic circuit for the F.H. cylinder. With any load on it it will bleed down and then cycle back up. With a heavy load such as a round bale it will cycle about every 10 seconds putting a noticeable load on the pump and engine in the process. Very annoying and puts a lot of heat in the hydraulic fluid.
It seems like it would simply be leakage in the cylinder itself, but could it possibly be in the spool valve? If the spool valve is not likely we'll go ahead with plans to rebuild the cylinder.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
