Posted by Andrew Z on May 23, 2012 at 05:22:15 from (72.10.122.33):
In Reply to: Re: compresion posted by blunted on May 23, 2012 at 05:16:23:
If you had a distillate / kerosene head compression could be as low as 80psi or so. At 70 PSI though it will make it a bit more difficult to start though. Run-able yes, power and reliability no so much / borderline.
Make sure you are doing the compression test correctly as well, wide open throttle, make sure carb is on and no choke.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
