Re: Now the liftall leaks
Posted by sgtbull on May 23, 2012 at 11:50:43 from (163.191.228.254):
In Reply to: Now the liftall leaks posted by jbp on May 22, 2012 at 08:19:59:
Use a piece of 1/2" flat stock that is wide enough it doesn't bend easily. I used a piece of 1/2" by 2" by 8" that worked great. It will fit the slot perfectly... punches, ill fitting pieces of metal, etc will potentially crack or distort the groove.. can make it run noisily later. Use a piece about 6 or 8 inches long and smack it w/a two pound hammer.. A good sharp rap works well in "breaking it loose." Heavier hammers will work, if you can swing 'em fast enough.
