Re: SMD fluttering at idle
Posted by d282 on May 23, 2012 at 12:50:47 from (209.152.94.237):
In Reply to: Re: SMD fluttering at idle posted by Dan MD on May 23, 2012 at 12:44:30:
Been there and done that. If that hole is not perfectly round or has a
nick in it you will get a drift in the spray of fuel causing uneven
burning and causing a miss. If that pre-cup is good, then have the
injector checked again. You will either have to do a lot of looking to
see if a good set even exists anymore, or put up with the slight
miss at idle. Good Luck.
