timing your pump won't crack your head, finding "center" for your individual pump takes time and patience, and advancing it until it misses won't crack the head, as you are only running it for a minute or two. If you advanced it and plowed all day all bets are off.
Like someone says usually 2-6 degrees but everyone is a bit different. SMD all have the same way to start, but each one also has its quirks as well. Let us know what you find out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
