Re: SMD fluttering at idle
Posted by sflem849 on May 23, 2012 at 15:44:51 from (69.197.84.39):
In Reply to: SMD fluttering at idle posted by Dan MD on May 23, 2012 at 14:11:51:
Thanks Dan, I'm going to go check that out. I reread my post, I wasn't trying to jump you. I just never heard that causing cracks. We have a local guy here that was a service tech when these were brand new. He is sharp and is on YT. I am not sure if he posts or just reads. I know he reads because he will read my questions or follow what I am doing with my MD. Then I will call him and he will say something like "I figured you would call" :lol: (if you are reading this I am getting close to calling you on my rear main lead)
d282 - Can you weld up the bad spots to clean them up? I think I have enough to make a good set, but one is a little fishy.
