Re: 300 update, TA linkage and PTO seasonal disconnect?
Posted by wisbaker on May 23, 2012 at 18:53:05 from (207.118.181.106):
In Reply to: 300 update, TA linkage and PTO seasonal disconnect? posted by Zachary Hoyt on May 23, 2012 at 18:34:28:
I think I'd pull the sticking valve to see what you can see, check the valve, give the stem some love with some really fine sandpaper (600+). If you have to you can ream the valve guide out. With the valve out you could try the hand lapping thing on the valve face, the twisty motion might solve your sticky problem on the stem. If you were wanting to get really extreme take the valve out, polish up the stem, stick it back into the head with out the spring, chuck the stem end into a cordless drill and spin it slowly while spraying a lubricant on the valve stem while moving if in and out, kinda a "twist, lube & stroke motion"(get you mind out of the gutter now).
