Re: bd 154 glow plug up grade
Posted by jimb2 on May 23, 2012 at 19:36:13 from (99.241.38.122):
In Reply to: bd 154 glow plug up grade posted by international 606 on May 23, 2012 at 16:36:19:
Hi 606, this was posted by LJD on Jan 14, 2012:
The IH B414 (BD154) uses the exact same glow plugs as a Mercedes 190D car. There are complete "fast heat" glow plug upgrade kits sold now for the Mercedes that direct fit the IH B-275 and B-414. No need for any adapters. Kit comes with four 12 volt plugs that get wired in parallel instead of series - and a controller.
Complete kit with four fast heat plugs, new wires, relay, controller, etc. is $144. Here's the parts list:
The complete conversion kit includes the following
* Heavy Duty Manual Relay
* Quality push button hole mount switch
* Mercedes factory 80 amp fuse holder
* 2 - 80 amp strip fuses
* Correct size and length of wire needed
* All terminal connectors required
* 4 Upgraded Pencil type Fast Glow Plugs
* Three New Glow Plug Wires
* Complete step-by-step illustrated instructions
http://www.mercedessource.com/node/8320
You can by the kit without the controller for $80 - $120. Here is one on Ebay -but I'm sure you can find cheaper elsewhere . . .
http://www.ebay.com/itm/MERCEDES-QUICK-FAST-GLOW-PLUG-KIT-190D-200D-220D-240D-/190579548413
And you could also just buy four plugs for $15 each and figure out the rest yourself.
If you order any Mercedes kits - make sure you verify the have the 18 mm glow plugs and not the newer smaller ones.
The correct fast-heat Bosch Duratherm plug to fit your B-414 is Bosch # 0250201044. Threads are 18 mm X 1.5 - just like your originals. Work at full 12 volts and draw 20 amps each when cold and taper to 8 amps each when hot.
You can buy just the plugs at $16 each at Amazon.com and several other places.
JimB
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
