Re: What's the plate bolted to block behind carburator on...
Posted by Bob M on May 23, 2012 at 19:59:45 from (74.67.189.51):
In Reply to: What's the plate bolted to block behind carburator on SH? posted by Va Gasman on May 23, 2012 at 19:36:52:
That plate is the block water header cover.
If the cover shows no signs of coolant leakage you can probably get by leaving it alone. However if it were mine I'd take it off, check the inside of the cover for corrosion then reinstall it using a new gasket.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
