Yes the disconnect lever has a hole slotted to edge that should be drilled. Lever has a shaft that goes through plate with another short lever inside that slides a drive dog on splines.
Probably the shaft or inside lever is twisted or damaged and thats probably from worn or damaged drive dogs wanting to slide the dogs out of mesh. Seasonal disconnect shifter parts won't handle the pressure.
Could find a solid splined coupling inside replacing the dogs. Some don't bother to remove all the shifter parts when replacing the dogs.
Not hard to remove plate and see whats up but oil needs drained. Any replacement other than shifter parts requires split.
Pin and connecter link releases the T/A clutch when main clutch pedal is pushed down. Unless the rollers, pins and springs are completly shot or removed from the T/A unit, bind up and hard gear shifting is the result of the linkage not adjusted and operating correctly.
May want to make sure the engines is okay before worry about the other parts. Suspect you probably end up with a internal T/A clutch repair or maybe a complete center section removal to get every thing repaired.
For the howling maybe the first check would be to see if oil is in the pto unit. Or if the seasonal disconnect will disconnect it, see if that stops it. Then go from there.
Forgot to say sometimes you can find the seasonal disconnect dogs welded together.
This post was edited by D Slater at 05:51:46 05/24/12.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
