Re: What's the plate bolted to block behind carburator on...
Posted by Super-H-Mike on May 24, 2012 at 06:44:51 from (76.164.146.98):
In Reply to: What's the plate bolted to block behind carburator on SH? posted by Va Gasman on May 23, 2012 at 19:36:52:
Those coolant passage covers will occasionaly rust through . You can get a repo/new one fairly reasonable. And there probably will be rust/crud built up behind there. You can snake it in there later if it fails, but if you already have it apart now is the time.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
