Re: IH 3 point top link
Posted by old on May 24, 2012 at 08:21:44 from (209.86.226.32):
In Reply to: IH 3 point top link posted by BartO on May 24, 2012 at 06:44:06:
They make center links or top links that are long one or shorter ones. I have found them in 2 or 3 lengths and in your case you need a shorter one. My local Farm and home place has the common long one and then they have one that is about 6 inches shorter
