Posted by Owen Aaland on May 24, 2012 at 13:14:51 from (216.47.35.138):
In Reply to: 300 making noise posted by old on May 24, 2012 at 12:32:17:
To check noises with clutch bearings, with the pedal released the bearing should not be touching the release levers on the pressure plate and will not be turning so there will be no noise. As you start to press down on the clutch pedal when the bearing starts to touch the release levers the bearing will start to spin and any noise should start then. If you continue to press down on the clutch pedal until the clutch disk is released the pilot bearing will begin to spin as the disk slows down. By listening to when any noise starts you can determine which bearing is making the noise.
In your case the noise happens when the clutch is totally released so if you have the correct free travel in the clutch adjustment the noise is not in the clutch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
