Re: Low Idle SH
Posted by Bob M on May 25, 2012 at 06:22:28 from (74.67.189.51):
In Reply to: Low Idle SH posted by GordoSD on May 24, 2012 at 22:14:25:
Had the same problem with my SH. Turned out the governor to carb linkage had a bit wear and needed readjusting.
Here's the procedure:
Remove the gov riser cover (sloped cover at the top of the gov). Remove the cotter then pull the connecting rod pin from the bellcrank. Loosen the bellcrank locknut.
Next pull the connecting rod upward and rotate the carb throttle shaft clockwise so both are against their stops. With the parts held in this position the bellcrank pin should fit freely into the bellcrank. If it does, adjust the bellcrank up or down on the connecting rod until the pin fits freely.
Finally replace the cotter pin and tighten the bellcrank locknut.
If that doesn't do it, remove the governor side cover and check the idle speed adjustment screw (the upper screw on the gov input lever). With the gas handle set at "idle" the screw should be against the stop. If it isn't adjust the throttle handle to governor rod length until it is.
Now test the idle RPM. If it STILL idles too fast, adjust the gov idle speed adj screw as required.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
