Re: 49 farmall starting trouble
Posted by charlie M on May 25, 2012 at 11:26:10 from (74.41.94.226):
In Reply to: 49 farmall starting trouble posted by Cary brief on May 25, 2012 at 10:39:00:
I'd try a couple of easy things first. Pull the plug on your carb and see if gas will run for a minute or so. If it flows you don't have a pluged fuel line. You could still have a carb problem from sitting and jets gettng plugged up. Pull a spark plug, turn over th engine and see if you have spark. You could have corroded points from sitting. If neither of things finds an issue you could have bigger problems. You do need to have a battery with enough power to turn the tractor and fire the plugs. A weak battery often can't do both.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
