Re: 49 farmall starting trouble
Posted by JRSutton on May 25, 2012 at 12:02:02 from (75.130.109.233):
In Reply to: 49 farmall starting trouble posted by Cary brief on May 25, 2012 at 10:39:00:
agree with charlie - after sitting for 8 months, it's a given that you should clean up the points, just becuase. Just touch them up with some very fine sandpaper - nothing crazy, just enough to kind of "wipe them off".
Also pull each plug, clean it off, and make sure you're getting a good spark to each.
Though it does sound more like a carb issue.
First of all - fuel filters are generally not needed and only introduce another weak link. If it can be removed from the picture easily enough, i'd do that. If not - just be sure fuel's flowing through good.
I'd pull the carb off, take it apart and give it a thorough cleaning - clean out all the little passageways. Then start fresh from there and see what happens.
With a known good spark in all cylinders, and a clean carb - most likely it'll fire up.
Tip cleaners work well for tiny passages (sold in packs for use on torches - any home depot has them)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
