Re: 49 farmall starting trouble
Posted by Bill in NJ on May 25, 2012 at 12:14:24 from (4.248.72.75):
In Reply to: 49 farmall starting trouble posted by Cary brief on May 25, 2012 at 10:39:00:
Seems to me if you got it running on starting spray it's either a fuel delivery and/or a carb problem. Keep in mind H's have a gravity fuel flow system with no pump. A filter in the line will usually cause excessive flow resistance. There should be a glass cup used as a filter at the exit of the fuel tank. Anything more than that will cause problems. As stated, remove the plug at the bottom of the carb bowl and you should have full flow our of the hole. Once you have good fuel flow, take the carb off and give it a good cleaning. It doesn't seem like it is the porblem but taking the distributor cap off, LIGHTLY sanding the points and resetting the gap cannot hurt a thing. Be sure the inside of the cap is dry before reinstalling it. Goo Luck.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
