Re: Touch Control Troubles
Posted by WellWorn on May 25, 2012 at 12:44:20 from (69.95.14.56):
In Reply to: Touch Control Troubles posted by gene bender on May 24, 2012 at 20:59:32:
There are 4 check valves in nylon carriers in the TC block. Are you sure you have them installed correctly? Two are "in" and the other two are "out".
It sounds as if one is in backwards. The blow-up diagram with the kit should give the details.
Good luck,
Well Worn
