Re: No start A Farmall
Posted by El Toro on May 25, 2012 at 12:54:24 from (108.3.225.57):
In Reply to: Re: No start A Farmall posted by Gordoro on May 25, 2012 at 12:26:28:
Squirt some engine oil on top the pistons after removing the sparkplugs. Then spin the engine over and then squirt some oil on top of them and replace the plugs. Then see if the engine fires when attemping a start. If it doesn't fire remove the plugs and do a compression test or have someone do it and see what your readings are. Low suction means low intake manifold vacuum. When was that last time this engine ran? It may need an engine rebuild. Hal
