Re: Farmall H Valve Settings And Spark Plug Wiring Order
Posted by The Red on September 26, 2000 at 14:28:26 from (12.75.197.68):
In Reply to: Farmall H Valve Settings And Spark Plug Wiring Order posted by Greg on September 26, 2000 at 14:19:24:
Greg I set the valve clearances at .018 cold. .017 warm is the proper clearance. The firing order should be stamped on the block above the distributor. 1-3-4-2. Someone has mentioned to also set the valve clearances using the firing order.
Post A Followup
: Re: Re: Farmall H Valve Settings And Spark Plug Wiring Order
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
