Re: Farmall H Front Wheel Wobble
Posted by SadFarmall on May 25, 2012 at 17:58:30 from (121.79.19.84):
In Reply to: Farmall H Front Wheel Wobble posted by shane ingram on May 25, 2012 at 17:36:43:
The seals are still available from CaseIH dealers. If you remove the old seal, any bearing supply shop should be able to match it.
SadFarmall
