Re: steering gear A Farmall
Posted by Jim Becker on May 25, 2012 at 18:32:31 from (173.74.120.222):
In Reply to: steering gear A Farmall posted by TimWafer on May 25, 2012 at 09:17:31:
Does the whole arm move up and down or does it swing up and down with the back end staying at about the same location? Restated, does the shaft move up and down or not?
If the whole arm is moving, Gene's explanation covers it. If the arm is swinging up and down, the arm has loosened on the shaft and you need to replace the arm and shaft. You may get into it and still find the parts Gene listed need to be replaced.
