Re: new engine c169 no oil pressure
Posted by Bob And on May 25, 2012 at 19:28:28 from (72.106.249.108):
In Reply to: new engine c169 no oil pressure posted by loch on May 23, 2012 at 16:16:33:
I"d say that your oil pressure relief valve in the oil pump is stuck partially open. Or the oil pressure regulating spring is weak or broken. You are correct when you say there is no adjustment there but the valve could be scored or just plain stuck. Make sure it works freely and check the spring for breakage etc.
