Re: Farmall 400 burning up points
Posted by pete 23 on May 25, 2012 at 20:30:43 from (74.32.231.176):
In Reply to: Farmall 400 burning up points posted by Theron Dickinson on May 25, 2012 at 20:22:55:
Take a close look at your coil. It probably says 12v R which means to be used on a 12 volt system with a external resistor. At any rate, take a ohm reading of the primary windings. If it is less than two ohms it is a 6 volt coil, 3 to 4 ohms it is a true 12 volt coil.
