Re: Farmall 400 burning up points
Posted by Janicholson on May 25, 2012 at 20:32:47 from (67.72.98.45):
In Reply to: Farmall 400 burning up points posted by Theron Dickinson on May 25, 2012 at 20:22:55:
The points can handle about 3.5 amps for a normal load. Yours res being subjected to much more current than that. Thus the coil is not correct. The coil will have between 4 and 5 ohms of resistance if it is indeed a 12volt coil. (disconnected at one small terminal and measured across the small terminals.) If it is more like 2 to 3 ohms, it is a resistor required coil.
I realize you indicated it was correct, but there are not really any resistors inside coils, they are just wound with more smaller diameter wire. If it is low resistance as above, put a resistor from a mid 1960s Chevrolet between the ignition switch, and the coil. Jim
