I agree with the other fine gents. The points must be switching more current then they are designed for (around 4 amps is a typical maximum current)
ORRRRRRRRRRRRRRR
The condensor is bad even though its "new"
Id stick an ohm meter on the low ohms Rx1 scale on the coils LV primary between its little + and - terminals and it should measure around 3 to 4 ohms. If so the coil is NOT the problem. HOWEVER if it reads like 1.5 to 2 or a bit over ITS A 6 VOLT COIL AND NEEDS AN EXTERNAL SERIES VOLTAGE DROPPING (12 to 6) BALLAST RESISTOR otherwise it overheats and the points burn up quickly.
1) Check coils LV primary resistance to insure its a 12 volt coil, if not replace it
2) If the coil passes TRY A NEW CONDENSOR
Of course the condensor needs wired to the points terminal and well grounded
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
