Your coil is for a NEG ground system. Ground goes to the distributor,so if it is wired + on the distributor, then your built in resistor is not working at all, you have it on the output side not the input side as on a NEG ground system. I believe you need a new coil and ballast resistor(separate).
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
